When I want to get a report in ideCAD Static 7, I can't
"ogunaydin":36b8rj0i" said:
I can't get a report when I want to get a report in IDECAD 7 STATIC. I would appreciate your help. Have a nice day. close the program.Delete the files under "C:\ProgramData\ideCAD" folder. Run the program and try again. Your problem may be solved.
'Failed to run C:/Program Files/ideCAD/ideCad Static 7/iderpt.exe.' error. I tried to do what you said, but there is no program data, so I couldn't delete it.
Programdata folder is hidden by default, you can see programdata folder if you check show hidden items from Control panel/Folder options. If you call our Bursa office, we will connect to your computer with remote access and help. ideYAPI Bursa office: 0 224 220 67 17 For remote connection program:
