When I take into account the heat effect, I get beam Nmax error
Re: When I consider the heat effect, the beam gets Nmax error Hello, my suggestion: --Remove the curtains on the left and right (I guess retaining wall) in the basement of the building, if necessary, solve them separately as a retaining wall. -- Since the height of the building is less than 40 m, you do not need to make a temperature difference calculation. You can review the document below. Ünver ÖZCAN A document on the shrinkage effect in reinforced concrete structures and the use of cracked section stiffnesses in thermal calculation (Uğur ERSOY, IMO Technical Journal/ April 1991):
