yunussacikk
When I print out, the dimensions between the axles are fractional (for example, 358.6), how can I set it as an integer?
In the dimensions given automatically by the program, the values after the comma are also written. you can get the number of digits to zero."yunussacikk":26c1inzq" said:How can we prevent taking fractional measurements with settings...I couldn't prevent fractional measurements
"yunussacikk":15io8ryp" said:it gives a fractional measurement even though I selected the digit number as 0. I added the project, you can check the mold plan, the dimensions seem to be fractional. It is done automatically by taking that much. The axles are given as xx.5 cm. There is no chance to change without changing the coordinates of the hangers. However, you can delete the existing dimensions in the mold plan and resize with any rounding you want using free or intersection dimensioning.
