When creating a staircase, it perceives the first step as a landing.
Re: When creating stairs, it is perceived as landing Hello; The problem is that the edges of the closed polygon where the stair climb direction line starts and ends meet at the same point with no other line segments in between. As a solution, when creating a closed polygon for the stair area, add another 1cm long piece to create the closed polygon as you can see in the attached screenshot. Best regards.
Re: When creating stairs, it perceives it as a landing
"sonsamuray":np4ehe3a" said:
When starting to create stairs, it perceives the first step as a landing. I couldn't get past this problem. It's on the ground floor. Thank you
You can create the ladder as in the attached project Note: The arms of the ladder on the mezzanine floor were also not connected to each other. The corrected version is attached.
Re: It perceives the first step as a landing when creating stairs
"Levent Özpak":sdh9vjbq" said:
"sonsamuray":sdh9vjbq" said:
It perceives the first step as a landing when creating stairs. I didn't get over this issue. Ground Floor. Thank you
You can create the ladder as in the attached project. Note: The arms of the stairs on the mezzanine were also not connected to each other. The corrected version is attached.
Thank you. I would have two questions. 1. I modeled the first step as one, you modeled it as two, multiple steps are modeled in a straight staircase, but how is it done in shaped ones? 2. How do we draw a spiral line in the form of a ladder when defining the calculation axis in spiral staircases?
Re: When creating a staircase, it is perceived as a landing first basa
"2m project":3t89iymt" said:
Hi; The problem is that the closed polygon edges where the staircase exit direction line starts and ends meet at the same point without any other line segments. As a solution, when creating a closed polygon for the staircase area, as you can see in the attached screenshot, add another 1cm long piece to create the closed polygon. Regards.
Thank you. I understood very well.
Re: When creating a staircase, it perceives it as a landing
"sonsamuray":300kpmgg" said:
I had two questions: 1. I modeled the first step as one, you modeled it as 2, multiple steps are modeled on a straight staircase, but in shapes how is it done?
The first two steps of the staircase on the ground floor are modeled as a separate branch. (It can be seen from the route objects in the project.) In general, it would be appropriate to define separate areas for the rotary arms and straight arms of the stairs.
"sonsamurai":300kpmgg" said:
2. How do we draw a curved line in the form of a ladder when defining the calculation axis in spiral staircases?
Stair reinforcement calculation axes and reinforcement drawings have been developed for straight-armed staircases. Good work
