What should I do to see if I have any shortcomings?
statikçim
HELLO, I STARTED WORKING ON IDECAD 7-8 MONTHS AGO, AND I HAVE GOT ALL MY EXPERIENCE, EDUCATIONAL VIDEOS AND FROM PEOPLE IN THIS FORUM. NOW I HAVE A SMALL AND BEAUTIFUL PROJECT THAT I WILL MAKE THE ACCOUNT AND CONTROL OF MYSELF. Mr. LEVENT OR OTHER AUTHORITIES SEEING ME: THE STATIC PROJECT THAT I SOLVE AT THE ATTACHMENT AND THE ARCHITECTURE OF THIS PROJECT IS AVAILABLE, I HAVE NOT ANALYZEED HERE YET, FROM THE FIRST I HAVE TO APPLY, IT WAS THE FIRST PROJECT TO BE APPLIED. WHY I AM AWARE OF MY DEFICIENCIES HERE AND WHAT I SHOULD CORRECT, I WANT YOUR HELP. I AM AWARE OF THE ERRORS IN GEOMETRIC CONTROL, BUT I CANNOT FIND A SOLUTION TO BE DONE. BECAUSE THIS PROJECT IS TOO SMALL, I HAVE TO DISTURN YOU IN SUCH DETAILS. I ASKED SOME QUESTIONS ABOUT PRE-RELEASES AND OTHER QUESTIONS FOR THIS PROJECT. I DEVELOPED MYSELF A LOT WITH THE HELP OF LEVENT. I put into practice what I understood and drew again from scratch (I haven't entered the foundation and ladder yet) 1) HOW DO I MAKE THE PARAPET HERE? AS I HAVE READ IN THE FORUM, THE PANEL IS NOT DRAWN. HOW DO I ENTER AS A LOAD? MY FLOOR WHERE PARAPET WILL BE MADE IS FLOOR FLOOR. 2) IN MY ANALYSIS SETTINGS, I REQUEST YOU TO TELL US IF THERE ARE FEATURES THAT I CAN'T USE, BECAUSE I DON'T KNOW THAT IDECAD OFFERS IT. 3) ALSO, I DIDN'T GIVE THE ERROR ON THE CONSOLE FLOOR ON THE CEILING OF 1.BUDRUM, HOWEVER IT WAS THE SAME IN MY PREVIOUS SOLUTION.
Re: I REQUEST YOU TO REVIEW IN DETAIL BECAUSE MY PROJECT IS SMALL, IT IS NECESSARY IF IT IS NOT DIFFICULT FOR THOSE WHO WILL ALREADY BE INTERESTED, BECAUSE IT IS NO LONGER MADE SPECIALIZED . THANKS TO THOSE WHO TAKES THE TIME TO INTEREST... (By the way, I just realized that if I was gender, it was opening in the demo anyway)
Re: I WANT SOME HELP FROM THE AUTHORITIES THAT HEAR ME Start the carrier system behavior coefficient from R=7. Solve with a semi-rigid diaphragm Make the beams continuous Do not stick the high beam into the lower beam You can apply live load reduction Make the elevator floor live load 500 Make the balcony floor live load 500 Make the rib slab live loads with the wall on it 350 Check the beam wall loads (12 cm aerated concrete not less for the outer wall) Take care to connect the beams from the columns to the columns Place the ladder, dissolve it together with the structure. I marked the corrections for what you said in the same file and put them side by side so that you can examine them. Also, I just added the file that I edited myself. Place the beam widths on the columns (in accordance with the regulation on the narrow side) Simple mistakes remain, you can fix them with the foundations
Re: I NEED SOME HELP FROM THE AUTHORITIES THAT HEAR ME
"NYILMAZ":22qejazs" said:
Start with the structural behavior coefficient R=7. Make a solution with a semi-rigid diaphragm Make the beams continuous Do not stick the high beam into the lower beam You can apply live load reduction Make the elevator floor live load 500 Make the balcony floor live load 500 Make the rib slab live loads with the wall on it 350 Check the beam wall loads (Isn't it less for 12 cm aerated concrete exterior wall) Take care to connect the beams from columns to columns Place stairs , solve it together with the structure. I marked the corrections about what you said in the same file and put them side by side for you to examine. Also, I just added the file I just edited again. Place the beam widths in the columns (in accordance with the regulation on the narrow side) Simple mistakes remain, you can fix them together with the foundations. quote] thank you very much i am starting to work on these now mdi. There are some points I'm stuck on, I'll need your help again after examining it a bit. it was really appreciated, thank you for your work.
Re: I am trying to create stairs with the route command to see if I have deficiencies and what should I fix, but after a certain number of steps, the landing comes out and I cannot do the rotating part. I am encountering the error "must be" very often, I wonder how to create a ladder to avoid this warning???
Re: Check if I have any deficiencies and what should I fix If I really understand the part of the engine room with this staircase event, I will feel incomplete but a little full now 8-) I thank those who will help
Re: Check if I have deficiencies and what should I fix The L stairs and route objects you want are attached. Good luck with
