What should be the thickness of the flooring?
xenix
If we solve a 5.90m x 5.50m slab with 13 cm thickness with fi10/35 spacing flat + pile, will vibration be felt on this slab? should i increase the thickness?
Re: slab thickness ? if it is residential, then 15 cm is sufficient. If the workplace is in the middle of it, add a single or double beam
Re: slab thickness ? I solved a wider (6x 6.3) slab with 14cm, but there was a slight vibration, I think 14cm would be enough here, thanks
