What should be the Bored Pile depth?
huseyinakkus56
Hello.. I need to make bored piles for the attached project. However, I've never done it before, I'm waiting for your help; - what should be the depth of the pile (should it be the distance from loose soil to tight ground, or should it be drilled a little deeper?) - how should I determine the number of piles and its diameter (should I put them under columns and curtains?) * Qem= 14.4 , Bearing Coefficient: 2304 , Z3 / C . There is very loose ground up to 5 m, and loose soil up to 7-8 m.
Hi, Pile diameter, length and spacing should be given in a way to safely carry the axial forces on the pile and to provide minimum conditions. (It can be checked whether the loads are transported safely from the "Pile bearing capacity verification" report.) Piles can be defined at equal intervals under the entire raft foundation. Good work
