aykuthanbudak
Should I change
Log in or register now.
base type? I'd appreciate it if you guys commented.-- Two of the continuous foundations were having soil problems,"aykuthanbudak":lvj8pix7" said:*why didn't you find the continuous foundation system suitable
-- You cannot define a linear load on the rib in version 7,"aykuthanbudak":lvj8pix7" said:*I defined linear loads on ribbed flooring . Are these not enough?
--Add it if you want, but there is no problem in this case either."aykuthanbudak":lvj8pix7" said:*should I add carrier curtain to the system
"aykuthanbudak":1iwmbjfy" said:*why didn't you find the continuous foundation system suitable
Hello, Additionally in version 7 In the rafter raft foundation system, no superstructure interactive solution is envisaged. If the floor group is C or D, since Tdy 2007 requires a superstructure interactive solution, it would be appropriate to design the foundation system as a beamless raft in terms of program and regulation compatibility."unver":1iwmbjfy" said:- Two of the continuous foundations had ground problems
In case of semi-rigid solution, linear slab loads defined on ribbed slab are taken into account in version 7. Good work"unver":1iwmbjfy" said:In version 7, you cannot define linear load on ribs.
