What is the Minimum Beam Width for Double Stirrups?
onderyk
In the static project I have made, for the double stirrup that is seen by the program, min. I made the width of B 50 instead of 40 without realizing it, I did not encounter any restrictions on this in the standard regulation. NOTE: the project is a hollow floor slab and all my beams are in size 50/30. As a matter of fact, there is only one stirrup on these beams, is there any problem??? I will be glad if you can help...
Re: What is the Minimum Beam Width for Double Stirrup? If you are making a flat beam, I think your 40 cm red beam will be more stable. Or you can draw Skinny, but it takes time. the choice is yours
