Ismail Hakki Besler
Administrator
If the buildings with large gaps in the plan and also the buildings with A2 and A3 irregularities are solved with the classical rigid diaphragm assumption, erroneous results can be obtained that are far from the real behavior of the structure. For this reason, the Earthquake Code requires that these types of structures be taken into account. We divide diaphragms into three main groups: 1) Rigid diaphragm Axial force cannot be calculated in beams when a rigid diaphragm is accepted. Deformations in the floor plane are neglected. 2) Semi-rigid diaphragm (Elastic diaphragm) The finite element model, which is created by dividing the floors into shell elements, is the static and dynamic analysis of the structure by including beams, columns, ribs, shears, foundation beams and raft foundations into the global stiffness matrix. In the model, floor masses are considered as distributed masses along the floor. 3)Flexible diaphragm Structures that do not have slabs or the slab stiffness is too small and will not form a diaphragm. ideCAD Static 7.00 is a program that can perform static and dynamic analysis according to these three conditions. You can download the latest version containing the Semi-Rigid Diaphragm solution from the link below:
Log in or register now.
There are many studies in the literature on the subject semi-rigid diaphragm you will find many documents:
