What does the reinforcements in the basic application plan mean?
statikçim
hello, what do the accessories in the basic application plan that I have clouded in the appendix mean? compaction equipment? I got this drawing from idecad. I would appreciate it if you could enlighten me about the placement and size of the relevant reinforcements.
Re: basic sub-reinforcement
"staticçim":28t5p5s4" said:
hello, what does the reinforcements in the basic application plan that I have clouded in the appendix mean? is it compaction reinforcement? I got this drawing from idecad. if you can enlighten me about the placement and size of the relevant reinforcements I will be glad if it is the punching reinforcement, how will it be placed, that is, from where to start and in which directions to go?
Hello, The reinforcements you mentioned are additional bending reinforcements. Editing can be done as described in the link below.
Good work
Re: basic reinforcement
Good work
thanks for your interest, but I did not understand this distance thing, namely Kon x, Kon y and other dimensions I would appreciate it if you tell me. The values in my report are in the picture below: I mean, how should the placement be done according to the donatos in the drawing I sent before, or I am attaching the picture of the drawing below, if you can look at it without opening autocad and explain it here, I would appreciate it:
Good work
thanks for your interest, I'm alone in this distance thing i.e. I did not understand Kon x, Kon y and other measures, I would appreciate if you could explain. The values in my report are in the picture below: that is, how to place the reinforcements in the drawing I sent first, or I am attaching the picture of the drawing below, if you can look at it without opening autocad and explain it here, I would appreciate it:
DB106 1 Axle and N1 additional reinforcement area can be made as follows; The location of the reinforcement (distance from the origin); Position X=12.80 m., Position Y=15.17 m., Total length (width)=1.32 m. Make the coordinate box visible. Let the unit of operation be meters... -Click the Line command. -Press the X key on the keyboard. The cursor will be in cell X of the coordinate box. Type 12.8 and press Enter. -Press the Y key on the keyboard. The cursor will be in cell y of the coordinate box. Type 15.17 and press Enter. -Click left mouse button. The first point of the line has captured the specified coordinates. This point is the center of the place where the additional reinforcement will be placed. -The distance to which the additional equipment will be thrown was 1.32 meters. Now 0.66 m from this point. upwards and 0.66 m. Draw two perpendicular lines, pointing downwards. The distance between these lines is the section where the reinforcement will be placed. Since the length of the reinforcement is 120 cm (it is written on the reinforcement), this area can be created with lines as shown in the picture.
