yunussacikk
hello, what does the red tick in the ZK column mean?
			Hello, It means that the condition of columns being stronger than beams is not met. TDY Article 3.3 Examine .5 and 3.3.6. When the alpha value is greater than 0.7 but less than 1, the end effects of the other columns are multiplied by 1/alphai and a kind of penalty is applied. See the "TDY Equation 3.3 Control" tab in the screenshot you added You can see the information that the program gives about this control."yunussacikk":3rpglywn" said:hello, what does the red tick in the ZK column mean.
Not if alfai is greater than 0.70, but if alfai is 0.70 There are sanctions regarding the choice of ductility level if it is less than (TDY Article 3.3.6.3) You cannot solve the structure with a high ductility level."yunussacikk":1jyer19t" said:I can get a report with this warning. Is it mandatory to remove these warnings?
