What does "This beam bears cantilever flooring" mean
engineer_yildiz
QUESTION-A: IN A BUILDING WITH AN EXTRACTION, ONE EDGE OF THE OUTPUT IS CONNECTED TO THE COLUMN (S101), THE CONSOLE IS A BEAM (K101A), AND THE OTHER SIDE IS A STUD BEAM (K101B) PLUGED INTO THE BEAM (K100). THINK THERE IS NO FLOOR BETWEEN THESE TWO CONSOLE BEAMS: 1- FOR S101: SHOULD THE PICTURES BE MARKED THIS COLUMN BROWS THE CONCRETE FLOOR ON THE STATIC/ REINFORCED CONCRETE TAB? 2- FOR K100: SHOULD BE MARKED THIS BEAM HAS CONCRETE FLOOR IN THE STATIC/ REINFORCED CONCRETE TAB? QUESTION-B: IN A BUILDING WITH AN EXTRACTION, ONE EDGE OF THE EXTENSION IS CONNECTED TO THE COLUMN (S101) AND THE CONSOLE IS A BEAM (K101A) AND THE OTHER SIDE IS A STUD BEAM (K101B) ATTACHED TO THE BEAM (K100). SUPPORT THAT THERE IS FLOORING BETWEEN THESE TWO CONSOLE BEAMS: 1- FOR S101: SHOULD THE PICTURES BE MARKED THIS COLUMN BROWS THE CONCRETE FLOOR ON THE STATIC/ REINFORCED CONCRETE TAB? 2- FOR K100: SHOULD BE MARKED THIS BEAM HAS CONCRETE FLOOR IN THE STATIC/ REINFORCED CONCRETE TAB? QUESTION-C: IF THE CONSOLE BEAM IS NOT EFFECTIVE IN MARKING THIS PICTURING AND ONLY THE CONSOLE FLOORING IS EFFECTIVE: IN A BUILDING WITH AN EXTRACTION, ONE EDGE OF THE EXTRACTION IS CONNECTED TO THE COLUMN (S101) IS A CONSOLE BEAM (K101A BEAM) LET THE BEAM BE (K101B). SUGGEST THAT THERE IS A RIBBON (THREADED) FLOORING BETWEEN THESE TWO CONSOLE BEAMS PARALLEL TO THE CONSOLE BEAM: 1- FOR S101: COLUMN STATIC/ REINFORCED CONCRETE TAB THE COLUMN CONSTRUCTION CONSTRUCTION CONSOLE CONSTRUCTION CONSTRUCTION? 2- FOR K100: SHOULD BE MARKED THIS BEAM HAS CONCRETE FLOOR IN THE STATIC/ REINFORCED CONCRETE TAB? QUESTION-D: IF THE CONSOLE BEAM IS NOT EFFECTIVE FOR MARKING THIS Phrase AND ONLY THE CONSOLE FLOORING IS EFFECTIVE: IN A BUILDING WITH AN EXTRACTION, ONE EDGE OF THE STRAP IS CONNECTED TO THE COLUMN (S101) IS A CONSOLE HANDLE (K101A HANDLE HANDLE) LET THE BEAM BE (K101B). SUGGEST THAT THERE IS RIB (THREADED) FLOORING BETWEEN THESE TWO CONSOLE BEAMS IN THE DIRECTION TO THE CONSOLE BEAM: 1- FOR S101: COLUMN STATIC/ REINFORCED CONCRETE TAB THE COLUMN CONSTRUCTION CONSTRUCTION THE COLUMN CONSTRUCTION CONSTRUCTION? 2- FOR K100: SHOULD BE MARKED THIS BEAM HAS CONCRETE FLOOR IN THE STATIC/ REINFORCED CONCRETE TAB? QUESTION-E: IF THE CONSOLE BEAM IS NOT EFFECTIVE FOR MARKING THIS Phrase, AND ONLY THE CONSOLE FLOORING IS EFFECTIVE: IN A BUILDING WITH AN EXTRACTION, ONE EDGE OF THE EXTRACTION IS CONNECTED TO THE COLUMN (S101) IS A CONSOLE BEAM (K101A HANDLE BAR) LET THE BEAM BE (K101B). SUGGEST THAT THERE IS RIB (THREADED) FLOORING BETWEEN THESE TWO CONSOLE BEAMS IN THE DIRECTION TO THE CONSOLE BEAM: 1- FOR S101: COLUMN STATIC/ REINFORCED CONCRETE TAB THE COLUMN CONSTRUCTION CONSTRUCTION THE COLUMN CONSTRUCTION CONSTRUCTION? 2- FOR K100: SHOULD BE MARKED THIS BEAM HAS CONCRETE FLOOR IN THE STATIC/ REINFORCED CONCRETE TAB? QUESTION-F: IF THE CONSOLE BEAM IS NOT EFFECTIVE IN MARKING THIS PICTURING AND ONLY THE CONSOLE FLOORING IS EFFECTIVE: IN A BUILDING WITH AN EXTRACTION, ONE EDGE OF THE EXTENSION MUST CONTACT THE COLUMN (S101) AND THE OTHER SIDE TO THE BAR (K100). 1- FOR S101: SHOULD THE PRESENTATION THIS COLUM BE CARRYING THE CONCRETE FLOOR BE MARKED ON THE COLUMN STATIC/ REINFORCED CONCRETE TAB? 2- FOR K100: SHOULD BE MARKED THIS BEAM HAS CONCRETE FLOOR IN THE STATIC/ REINFORCED CONCRETE TAB? I WOULD LOVE TO ANSWER THE QUESTIONS WITHOUT SKIP.
Re: What does "This beam bears console slab" mean Hello, "Console carries slab" is an option that only concerns slabs. The presence of this option on the beam or column indicates from which side full grip (recessed) the slab will be taken. You can see the difference by examining the moment diagram of the slabs. If the console floor does not continue inside, it is a stand-alone console supported on the beam, this statement is important.
