What causes version difference in analysis results?
CSMKNR
WHEN I MADE THE SAME ANALYSIS BY CONVERTING THE SAME PROJECT BEFORE VERSION 8.030 TO VERSION 7.002, WHAT CAUSES THE VALUE DIFFERENCES BETWEEN THE TWO? I TRIED TO EXPLAIN THE SITUATION IN THE ATTACHMENT. WHICH VERSION IS MORE RELIABLE IN ITS SOLUTION?
Re: WHY IS THE VERSION DIFFERENCE IN THE ANALYSIS RESULTS?? If you add both the 8 version and the 7 version data that you get these results from, your friends will tell you where you made a mistake.
IF YOU EXPLAIN THE REASON I GOT DIFFERENT RESULTS IN RISKY BUILDING ANALYSIS, I WOULD LIKE IT. almost my fault
Hello, The situation you specified is a situation we know in version 8.030 you are using and has been fixed in version 8.1 Evaluate your project according to the RBT analysis results in Ver 7.022. Good work
