What can I do to overcome the stapling problem?
"salihaesen.52":1qu0ddq5" said:
https://we.tl/t-1HLgGgo1tu what can I do to overcome the stapling problem? and what causes the stapling problem, can you help? Thank you good work
Hello, The stapling problem is caused by the design-based punching stresses calculated according to TBDY 2018, exceeding the Concrete design tensile strength. Stapling checks, punching reinforcement calculations and reports were made within the scope of the Earthquake Regulation 2018 in the Ver 10.20 version. You can view the work done in the Ver 10.20 version from the link below.
To overcome the stapling problem on the raft foundation; The thickness of the raft floor can be increased . If the punching problem is in the outer columns and there is no amputation, amputation can be done. Concrete class can be increased. Column/wall size can be increased. Stapling reinforcement can be used in the Column-Curtain Properties/Punch Reinforcements tab... Bookmarks are not made automatically. You have to do it yourself by reviewing the raft stapling report and using the 2D possibilities)
Dude, you can right click on the column and go to properties and click on the punching equipment. There are a few equipping options out there, you can do whatever suits you.
"yunussacikk":1mgrpt7x" said:
can you show how to use the punching reinforcement in the program
Enter the properties of the column or curtain you want to use the punching reinforcement for. In the punching equipment tab, select the type of punching reinforcement you want to use. In the raft punching control report, the information about the punching equipment you use will be given. According to this information, you can edit the punching reinforcement drawings using the two-dimensional drawing possibilities.You can review the TBDY Building Earthquake Regulation Training Manual 3 example regarding the representation of punching reinforcement in the drawings(BA-3-36)
