First of all it is thought-provoking that you are still using version 6 of the ide. There are tiles in the system that are unnecessarily thick. Therefore, you get an error message about beams in geometry control. At the same time, you are unnecessarily increasing the mass of the building. Do not mark the elevator curtain as a flood curtain. (On all floors) Collect the p33-34 curtains in the elevator under one name. Apply live load reduction coefficient. Correct the carrier system behavior coefficient incorrect for systems with normal ductility level. Review the attic wall and floor loads. Review interior wall loads. Solve it with a semi-rigid diaphragm And most importantly add curtains to the system (for example, curtain S11 columns and column symmetries) I think s17 is out of place. See what happens after all this.
