Re: HOLLOW FLOOR WALL LOADS Hello 1-You can enter the loads of the walls on the floor with the Linear floor load command or with the wall object. 2-Add the weight of the filling to the additional load of the coating load in the unidirectional gear flooring systems. The load value changes depending on the unit weight of the material used. You can get information from the companies that produce the material
