S servany2 New Member Nov 10, 2018 #1 Is the wall drawn with the wall command just for visual purposes? Even after this drawing is made, should the wall load be entered on the beams?
U unver New Member Nov 10, 2018 #2 Hello "servany2":3mim9no6" said: Is the wall drawn with the wall command only for visual purposes? Should the wall load be entered on the beams even after this drawing is made Click to expand... It is not for visual purposes. The walls on the beam are taken as the wall load and shown in the calculation results. You can try and see in the system.
S servany2 New Member Nov 10, 2018 #3 Thank you for your help, Mr. Unver, I've been away from PC for a few days, I couldn't try it, so I asked again, thank you, good work
