wall drawing
cakilomer
Good work, while I was browsing the forum today, I came across a project, walls, roofs and windows were drawn, I came across an idecad static project. Is this project transferred from architecture?
Re: WALL DRAWING ? I draw the architecture in the buildings that I made myself in ideamimari and continue the project in ide static, both the program finds the wall loads automatically and the wall plaster, plaster tiles etc. I also take all my quantities. Using IDE together brings great convenience in project design. I also put an SS from my last building to give you an idea.
Can't this operation be performed using only idestatic? at least for a healthier solution for walls and roofs?
If you look at Siromar's answer, it says ideMimari and IdeStatik, so you can't enter elements like walls in IdeStatik. You can make panels and make spaces with elements such as windows and doors.
