Wall drawing in ideCAD 5?
serhans
Hello there. I am trying to learn ideCAD 5 from ideCAD 6 book. When I came to page 58 of the book, it was necessary to draw a wall in one example. I created it with Panel. However, the height of the panel cannot be adjusted either. There is only jeans and top jeans menu. The first thing that came to my mind was that the menus changed quite a bit as I passed from 5 to 6. If there is such a situation, I guess I will have to get ideCAD 6. Can you help with this?
Hello, I'm trying to learn ideCAD 5 from the
"serhans":39551c3g" said:
ideCAD 6 book. When I came to page 58 of the book, I had to draw a wall in an example. I created this with Panel.
On page 58, object dependency in general It is aimed to explain the interdependence of the objects and the logic of this by explaining the feature of the objects.Wall-door-window-external dimensioning for architecture, floor-beam in staic, panel-flooring, space-wall etc. for architecture can all be evaluated within this subject. There are no wall objects in both ' and 6', so you can't make that example exactly... (We will review that subject in the static book)
The height of the panel object is the height of the floor. We can shorten the top or bottom jeans with the top or bottom jeans.
The first thing that came to my mind was that the menus changed quite a bit while going from 5 to 6. If this is the case, I guess I'll have to get ideCAD 6.
Menus between 5 and 6 and There is not much difference in the order of commands. There are new possibilities. Demo versions include all possibilities, including saving, except printing. You can download and view it from our site.
Thanks for your interest. I installed the demo half an hour ago. It has been greatly improved in appearance, I like it. I am working with him now. I found it quite useful as a new engineer. Good work.
