WALL DATA ENTRY RECOMMENDATION
unver
1-When we transfer data from IdeCAD Architecture, walls are displayed under the floor formwork plan in the perspective window in IdeCAD Static, can't these walls be displayed above the formwork plan? 2-Can wall data entries be entered in IdeCAD Static as in IdeCAD Architecture? (on the formwork plan) 3-Due to commercial concerns, if the wall loads are entered like this, IdeCAD Static is said to be similar to IdeCAD Architecture. CONCLUSION: If Item 2 is made for IdeCAD Static users, manual calculation for wall loads will not waste time, and correct data entry will be easy. THANKS TO EVERYONE WHO CONTRIBUTED.
Hello Mr. Unver, it is in our notes 2 and 3. Regarding Article 1; With the settings/visibility of objects on the floors command, it is possible to adjust whether the architectural/static elements at the top/bottom are visible/not visible. In addition, the walls of the entire floor can be viewed in the perspective view. If you are stating a different situation from this, could you explain the subject in more detail? Thanks...
Explanation on the 1st item: When the architectural plan is passed, the walls appear as the walls of a lower floor. In the same situation, when we mark the mold plan of the floor in the perspective and view windows, the walls are seen on a lower floor. When the architectural plan is passed, the walls on the formwork plan should be seen so that we can decide whether to put beam-column curtains under those walls.
