Visualization->Beam Span Rebar Problem
MaFiAMaX
Hello guys, I have encountered a very strange problem. I talked to the ideCAD center, but I decided to write to the forum because they did not have the problem that I will talk about below. If anyone else has a similar problem, maybe we can find the cause. When I want to look at the "beam span reinforcement" value from the post-analysis visualization window, it shows the value both on the beam support and the texts are too small to read. I tried the following to see if the problem was caused by my model or the operating system, but the problem was not solved: 1-) I made a simple model from the ideCAD template file. 2-) I made a model from scratch on a computer with Windows 10 build 1709. When looking at the models that have been analyzed before, this problem does not appear, but when you analyze that model again, the same problem arises. I updated the video card driver to the latest and installed the driver with a clean install from the nvidia options, but in vain. I am using windows 10 build 1803 64 bit version. Video card nvidia 1050 Ti, driver 397.31
NOTE: To check your Windows version, open the Start menu and type "about" in the search bar. Just type it and hit enter
Greetings, You are right Mr. Erhan, when I read the message from you, I immediately tried a simple model (4m * 4m), I also had the issue you mentioned. Then one by one, I increased the axle spacings by 25 cm in one direction and then in the other direction. The result improved when I reached 575 cm * 400 cm. The situation that you said in all smaller sizes has occurred. If my communication system is Windows 10 Home version 1803, Video card is ndiva 950
Hello, In case of analysis according to the semi-rigid diaphragm method, in the visualization dialog, the brackets are shown close to the beam supports, in the fully rigid solution, in the beam span. It's not a case of windows version and video card. Good work
Here are my screens. It happened just like you said. Then I enlarged the dimensions as İbrahim Bey said, but it did not change. When I use the undo command to restore the values appear in the right place.
"saridurmus":1k3ym8zu" said:
Greetings, You are right Mr. Erhan, when I read the message from you, I immediately tried a simple model (4m* 4m), I also had the issue you mentioned. I increased the spacings by 25 cm. The result improved when I reached 575 cm * 400 cm. The situation you said was smaller in all sizes. If my communication system is Windows 10 Home version 1803, Graphic card is ndiva 950
Greetings, When you increase the axle spacing in the model, the analysis model As it breaks down, the semi-rigid diaphragm also disappears and it appears in the middle of the beam as Levent Bey said. If you analyze the model you changed the axis spacing again, you will see that it is written close to the support and in a small font. Thank you for your interest. When I looked at the previously analyzed models, I said there is no problem. I guess I was wrong because the analysis of those models was broken somehow.As a result, it has been like this for a long time, I just discovered it :) Instead of the middle of the beam It's okay to show it on the support, but the point size is. It will be fixed in future updates. Thank you to everyone who is interested, I wish you a good work.
