Virtual Memory Problem
cihaner
I ran into a problem trying to open the drawing of the basic application plan, it says virtual memory is low and the program closes. I tried it on another computer, still the same problem. I will be glad if you help.
Hello If you upload your project, we will try to help. Also, it would be better if you write the version you are working with...
Hi In control panel, go to system properties. Here, in the advanced tab, go to the performance settings, increase the virtual memory and try to draw again. If you still can't get a drawing, we'll try to help if you add your project. Good work
I reviewed your project. There is an error in the basic data entry. While modeling foundations, you can define raft or beamed raft foundation types, apart from single and continuous foundations. If you want to model raft foundation; Using the raft tile edge command, you must specify the raft boundaries and define a raft tile inside. If you want to model the rafter raft foundation in your project; You must connect all columns using continuous foundations and define raft foundations in areas formed by continuous foundations. A memory error may have occurred in your project, probably because you created a model against these rules. Good work.
Thank you for your early response and interest, but my question wasn't about how the basics were worked out. I know I'm wrong somewhere, so I asked for help.
