viewport freezes
cengizhan1025
Hello, I was trying to make my own settings in idecad after installing the licensed idecad program that I installed on my computer. But the problem started to occur in the perspective or other viewports on the right side of the workspace. The problem is that the view windows freeze, so when I hover over the window, I cannot play it in any way. But when I maximize this window, I can do left and right rotation as I want. Then when I minimize the window, whatever I did last stays there. Again, I can't operate on the window. This is just a bug in the right side viewport. Thank you for your interest in advance. How can I solve this problem?
"cengizhan1025":4330t04t" said:
Hi, I was trying to make my own settings in idecad after I installed the licensed idecad program I installed on my computer. But the problem started to occur in the perspective or other viewports on the right side of the workspace.The problem is that the viewports freeze, that is, when I hover over the window I can't move it in any way. But when I maximize this window, I can do left and right and rotate it as I want. Then when I minimize the window, whatever I did last stays there. Again, I can't operate on the window. This is only a problem with the right-side viewport. Thank you for your attention in advance. How can I fix this problem?
The problem may be related to the opengl rendering performance of your video card. We recommend a Nvidia GeForce video card. If you are using an Nvidia GeForce video card, update the video card drivers. There are two boards with an onboard low processor and an external high processor. When running the program, you need to run it with a high-processor graphics card. Optimal performance for desktop system requirements: - Intel i5-7600k - 64-bit Windows 7, 8 or 10 operating system - 16 GB RAM - Nvidia GeForce GTX 1050 external graphics card - 1920x1080 monitor resolution Desktop High performance system requirements for: -Intel i7-7700k -64 bit Windows 7, 8 or 10 operating system -32 Gb ram -Nvidia Geforce GTX 1060 -Minimum 1920x1080 monitor resolution Optimal performance system requirements for laptop : - Intel Core i5-7300HQ - 64 bit Windows 7, 8 or 10 operating system - 16 GB RAM - Nvidia GeForce GTX 1050M external video card - 1920x1080 monitor resolution High performance system requirements for laptop:[/ b] - Intel Core i7-7700HQ - 64-bit Windows 7, 8 or 10 operating system - 32 GB RAM - Nvidia GeForce GTX 1060M external video card - At least 1920x1080 monitor resolution
The processor of my laptop is in all the features of the high-spec laptop you mentioned below, but I still get the same problem, sir. Nvidia geforce gtx feature is also available.
"cengizhan1025":88rs38ji" said:
the processor of my laptop has all the features of the high-spec laptop you mentioned below, but I still get the same problem, sir. The nvidia geforce gtx feature is also available.
Update the graphics card drivers. Secondary with low processor Check if there is a card. When running the program, you need to run it with high, not low. If your question still persists after checking these steps, you can call our technical service, Bursa office, and have it connect to your computer with remote access. We will examine your question and help you to solve it. Bursa office: 0224 220 6717 Software you can use to get remote support:
It's ok. Thank you so much. The problem was caused by the update. I had one more question. Well, how can I reproduce this view or perspective window, so now I want to make 2 of them and 3 of them. Sorry, I'm just getting started so I blew your head off :)
"cengizhan1025":vhjifa2z" said:
Okay. Thank you very much. The problem was caused by the update. I had one more question. So how can I duplicate this view or perspective window, so now it's 2, I want to do it 3. Sorry, I'm just getting started. That's why I blew your head :)
In the ribbon menu, click Image/Window section/Image Configuration.In the window that opens, you can choose how many screens will be divided.
