Vertical load definition on curtains
201968
I define a vertical load on the curtains as in the photo, but I cannot display this load in the loading window.
Re: DETERMINING VERTICAL LOADS FOR CURTAINS
Whether the load occurs on the curtain due to the left and right distance values. Please check. Also give the Load value positive. Good work
Levent Bey, no load occurs. When I say user defined load in the display window, I can see the loads I have defined on the beam. I cannot see the loads I have defined on the curtain, I would appreciate it if you could help.
"201968":114mg9vj" said:
No load is seen in the reports
Vertical loads defined on the screen are not printed in the reports. However, they appear in the 3d analysis model. If you define a vertical load on the screen and add the IdeCAD project file that you cannot see in the 3d analysis model, we will review it. Good work
Mr. Levent, the project is attached and the attached photo shows the dimensions I want to effect the load on the p02 and p04 curtains.
"201968":eqg8xz22" said:
Levent, the project is attached and the attached photo shows the dimensions that I want to effect the load on the p02 and p04 curtains. Can't I define a point vertical load on the curtain? The distributed load can be defined. The defined loads are displayed in the 3D analysis model. Good work
