Version 8 floor parameters download name change
s_f_d
WE CAN CHANGE THE INDEX OF FLOOR PARAMETERS IN VERSION 7 FOR PROJECTS WITH DIFFERENT RIGID DIAPHRAGM. THE SAME MENU IN VERSION 8 NO RELATED TAB. I WANT YOUR HELP ON THE SUBJECT. GOOD WORK EVERYONE.
Hello, you can enter data in the Settings/Floor General Settings dialog. In the index column of the relevant floor, the names of the index are separated by commas as much as the number of diaphragms. For example, if there are 3 rigid diaphragms on the 1st floor, the rigid diaphragm indices are written in the order "1A, 1B, 1C".
I THANK YOU FOR YOUR ANSWER. WE CAN CHANGE THE FLOOR INDEX WHEN YOU SET IT FROM WHERE YOU SAY. LET ME EXAMPLE MY QUESTION A LOT MORE. HAVE A DILATATIONAL BUILDING. WHILE RECEIVING THE BASEMENT FLOOR MATERIAL PLAN, I WRITE KB101,DB101... I WAS DELETING A,B,C.. IN THE INDEX LIKE 1A,1B,1C.... ON THE RELEVANT FLOOR IN THE INDEX TAB IN FLOOR PARAMETERS IN V7. I CAN'T SOLVE IT IN V8. THANK YOU FOR YOUR INTEREST.
HAKAN, I DID WHAT I WANTED TO DO AS YOU SAID. THE PROBLEM WAS SOLVED, BY WRITTING COMMES AS MUCH ( , ) AS THE NUMBER OF Aperture. THANK YOU FOR YOUR INTEREST AND HELP. (GÜRAY TO YOU TOO)
