asilturk1981
I could not place and support the vault that I created so that it is fully on the columns and beams at the level of S14, S06 and S01. Also, I cannot find a solution with the structure as in the figure. Help please...
To support the vault to the beams For this purpose, I defined between the beams K1, K2 and K3, K4 and I would set the Vault elevation according to these beams.With the Define vault supports command in the Vault toolbar, the solution was selected together with the structure and the load transfer to the Beams and Columns was activated. You can examine it in the attached project."asilturk1981":3obunivr" said:I couldn't place and support the vault that I created so that it sits on the columns and beams at S14, S06 and S01 lines. Also, I can't find a solution with the structure as in the figure. Please help...
You're welcome, Yes, I noticed that when you wrote it, you can find the corrected version in the attachment."asilturk1981":3qwy7nwn" said:Thanks, Yüksel, a few problems have been solved, but when we look at the deformation results on the 3D frame screen, it seems that the vault is not supported on the columns in the middle section...
