Variable Rebar Drawing
kyuceturk
Hi, I searched the forum but couldn't find it. I have an indented, uneven foundation. Therefore, in some areas, I need to insert reinforcements of variable length and/or shorter than their foundation limits. Is there a way to automatically reflect this in drawings? Thanks
"kyuceturk":6l1xotpp" said:
Hi, I searched the forum but couldn't find it. I have an uneven foundation with indentations. So in some areas I need to insert reinforcements of variable length and/or shorter than the foundation boundaries. A way to automatically reflect this on drawings Thank you
You can define the slab edge and the raft plate as more than one eye, so that each eye has its own reinforcement axis.
I guess you have used it partly, but by using the commands in the attached picture, you can enter more than one reinforced concrete calculation axes and change the sweat they affect, so you can draw the reinforcements and get their number, length and quantities.
"kyuceturk":16h3bmj0" said:
Hi, I searched the forum but couldn't find it. I have a rough, uneven foundation. So in some areas I need to insert reinforcements of variable length and/or shorter than the foundation bounds. A way to automatically reflect this on drawings Thank you
Hello again, We can help if you add your project and indicate schematically what length of reinforcement you want for which region.
