v10.17 does not save raft
kemal59
Hello, while working on a new project that is very similar to a building that we had previously solved and completed with a 60 cm raft on the adjacent parcel, we were updated from v10.14 to v10.17 version, from that moment on, the raft basically seems to be a problem and we tried exaggerating up to 120 cm, but it still does not save. We are wondering what we are missing from friends who have the chance to take a look at the attached project. Thanks in advance.
Re: v10.17 raft increase the diameter of the upper and lower reinforcements in every good direction, decrease the spacing, recover in the Q18/15-10 band, renew the analysis by pulling the foundation height to the size you want, and correct the deficiency with the reinforcement.
Re: v10.17 raft Hello; Take care to pass the position of the raft foundation slab calculation axles through areas that will not create large support moments. Your project, arranged with a thickness of 60 cm, is attached.
, Yours sincerely.
Re: v10.17 raft The topic has nothing to do with the update from v14 to v17. First of all, you can reduce the raft floor thickness to 60 cm in your project. Define the 2nd (y direction) calculation axis of the raft slab in such a way that it passes through the raft opening instead of defining it over the group curtains. Thus, you can reduce the reinforcement selected for the main reinforcement, and you can place the reinforcement left over from the main reinforcement as additional reinforcements in the equivalent areas on the group bulkheads. However, in the project you have added, instead of using additional reinforcement, you are requesting unnecessary reinforcement space for the main reinforcement by passing the 2nd account axis through the most negative line. Note: For the message "Failed to create mesh for D336" you can give the finite element width 40 cm on all floors in D336. I am attaching it to the message so that we can use the project:
Re: v10.17 raft Overlooked in pre-geotechnical investigation. Thanks for all the replies, keep up the good work.
