Hello, the defined horizontal and vertical loads defined on the curtains can be seen in the 3D visualization. It is not shown in the report. it is registered in our job list. Good work"49emrah49":2umhfevn" said:Hi, the distributed load that I defined on the element is not visible in the report I received as a result of the analysis, can you help me. take it easy
You can print a screenshot of the visualization and add it to the report. You also have the opportunity to add a picture to the report program."49emrah49":2mwyatka" said:we are working with a foreign company and they want us to see the loads in the report. do you have anything to suggest. thank you.
Hello Mr. Erhan, Report format work has been done on the reporting of user-defined loads, test projects and documentation have been prepared. It has been forwarded to the software department.Software stage has not been started due to business priority."MaFiAMaX":1f4umbts" said:Greetings Mr.Hakan, I hope the job of displaying user-defined loads in the report has not been left in the background
Thank you for the information, Mr. Yasin."YasinTezel":1xpot7vm" said:Mr. Erhan Hello, About reporting user-defined loads Report format work was done, test projects and documentation were prepared and submitted to the software department. Currently, the software phase has not been started due to business priority."MaFiAMaX":1xpot7vm" said:Greetings Mr.Hakan, I hope the job of showing user-defined loads in the report is not too far behind
