Hello to everyone. After installing V10, I started getting a warning that Upper Floor Curtain is Thicker than Lower Floor Curtain in my projects. In projects with rigid perimeter curtains in the basement of the program, the thickness of the curtains on the ground floor is higher than on the basement floor. Although the same is true for the pitch in its symmetrical pattern, it does not give the same warning on that pitch. When I check the nodes, I don't see any difference. If anyone has the same problem, I would appreciate if they share how they solved it. Respects.
