Upholstery options add pile
ERHAN YALÇIN
Hello, Reinforced Concrete, when we activate the pile option for additional reinforcement in the slab parameters dialog, it seems that the pile lengths are not added to the reinforcement length in the formwork plans in the drawings with item number and reinforcement table. The pleated length is calculated in the reinforcement table and the quantities. I am an idecad version 7.022 user. Is there a way to deal with this situation or is there an update about it? Best regards, Thank you.
Hello, The situation you specified has been taken into our notes. This value can only be changed manually with the Change text command after receiving the pattern plan. Thank you for your report. Good work
"Levent Özpak":2vag3559" said:
Hi, The situation you stated has been taken into our notes. This value can only be changed manually with the Change text command after receiving the pattern plan. Thank you for your notification. Good work
Mr. Levent, Your interest and us We thank you in advance for the quick solutions you will offer.
