Unit in Deformation
k0ry
After analyzing the attached frame, when I want to read the deformation values, the ux value is 59. When I change the unit from the general settings, the values do not change dynamically. Is there a place where I can check the unit of this value? Best regards.
"k0ry":26ronpow" said:
After analyzing the attached frame, when I want to read the deformation values, the ux value is 59. When I change the unit from the general settings, the values do not change dynamically. Is there a place to check the unit of this value?
Design in the structure tree Right click on the line and click on the Design Settings line from the menu. You can change the unit from the Defprmation line in the dialog that opens. Good work
