ismail2982
ZF - TA and TB for Local Ground Class TA and TB for ZF - Local Ground Class could be entered in the first IdeCAD v10 version. But now I can't login. Will there be an update on this soon?
Isn't there a possibility to directly enter the coefficients and create the program?There is also only the import option.Even if there was an Export option, I could add in a suitable format accordingly."nurgulkaya":2sub9udh" said:Hi; There will not be an update on this topic anytime soon, because there is no need for an update. ZF class ground For TDBY 2018 - Table 2.1, it is written that site-specific soil investigation should be done and the coefficients that will enable us to obtain the spectrum are not given. You need to transfer the spectrum you determined as a result of your u]field-specific work[/u][/i] to the program as a txt file from the defined section in the Analysis Settings - TBDY 2018 Design Spectrum tab. Good work.
"Ismail Hakki Feeds":4ya1yfp8" said:The program does not generate spectrum for you. You can give another spectrum for Dusey if you want. You can use it in Dusey earthquake.
