Unable to create mesh for tiling.
evanes07
Have a nice day; While analyzing the project I added, it says that the mesh cannot be created for the basement floor D06 slab. I did a slab analysis, the problem does not appear.. It is a very urgent problem, can you take a look at it?
"evanes07":3onz14et" said:
Good afternoon; while analyzing the project I added, it says that the mesh cannot be created for the basement floor D06 slab.. I did a slab analysis, the problem does not appear.. If I have a very urgent problem, can you take a look?
Hello, input data so that a joint point is formed on K26 in the same coordinate at the point where the K05 beam connects to K26, recreate the slab. This is version 7 Since object connections are made automatically, such problems do not occur in version 8. Note: -The project was created in a coordinate far from the origin point.Enter data with the lower left corner close to the origin point.Good work
"Levent Özpak":svo8so7e" said:
"evanes07":svo8so7e" said:
Good afternoon; While analyzing the project I added, it says that the mesh cannot be created for the basement floor D06 slab. I did a slab analysis, the problem does not appear.. It is a very urgent problem, can you take a look at it?
Hello, input data so that a joint point is formed on the same coordinate on K26 at the point where the K05 beam connects to K26, Rebuild the floor. This is related to the 7th version. Since the object connections are made automatically in the 8th version, such problems do not occur. Note: -The project was created in a coordinate far away from the origin. Enter data with the lower left corner in a coordinate close to the origin. Good work
Good work Mr. Levent. I get the error Unable to create network for tile. I deleted and redefined my tiles. Nodal points overlap each other in the beam junction areas. However, I still couldn't fix the error. How should I go about correcting the error? I will be glad if you get back quickly.
"ezazile53":3k7u3ol9" said:
Good work, Mr. Levent. I get an error that the mesh cannot be created for the slab. I deleted and redefined my slabs. The nodes overlap in the beam junctions. However, I still could not fix the error. What should I do to fix the error. Urgent I would be glad if you could get back to me.
Hello, if you add the IdeCAD project file, we can review it. Good work
