Typical beams are entered automatically as in ribs. In the Cassette tab, if you enter both the typical beam numbers as + and select the horizontal vertical beams at the far left and the bottom, you will see the typical beams. Or any other shape; If you enter both values and select the joists above and to the right of the slab while showing the horizontal and vertical joists, you can still see typical joists within the slab. However, if you click on the intersection point of two ribs with the command, which is easier than all of these, you can specify typical beams from both directions at once.
