Two-way beveling on the column
ryildiz
In my attached project, I want to give a double-sided slant of 100 cm in the x and y directions to my column in the corner. It happens, but the inclined column does not fit the lower column completely due to rotation. Is there any other solution? Thanks in advance for your answers.
Hi, you can do it with Polygon column. 1. Create a closed area in column dimensions with the line command. 2. Skew the column in the column settings. 3. Convert lines to polygon columns with the Convert to Polygon Column command. 4. Place the formed polygon column by rotating it at the appropriate angle with the Rotate command. Also, the subject is explained at this link:
Good work
Mr. Hakan; I did it as described, there is no problem in that respect. However, the oblique column does not fit the lower column properly. Will there be a problem with the account?
"ryildiz":jftwywxw" said:
Hakan, I did it as described, there is no problem in that respect. However, the slanted column does not fit the bottom column properly. Is there any problem in terms of calculation?
It's okay, but check the analysis model to be sure. Displace the structure, if the column-beam junction moves together, there is no problem.
Hello there; I think this is exactly what you want to do... the model is attached, the line version of the polygon column is also available. Best regards.
"2m project":29vbuyvq" said:
Hi, I guess this is exactly what you want to do... the model is attached, it is also available in line form of polygon column. Best Regards.
Dear 2m project is exactly what I wanted to do. Helpful Could you please describe how you did it in terms of your business? Thank you in advance for your interest and concern.
