Turkey Building Earthquake Code 2018 DTS 1a school project
ottomancagatay
Good work, everyone, in Tbdy 2018, while choosing the performance target according to DTS 1 in the school project, we choose controlled damage as the normal performance target, and we choose the design according to the strength as the evaluation design. There is no problem so far. A 3-stage design is foreseen for us to achieve the advanced performance target. Accordingly, Dgt is applied for the KH performance target for such buildings by taking the building importance factor of 1.5 first, but this design is evaluated as ten designs, then the SHGD approach is applied to provide the Sh performance target under dd3 earthquake ground motion and also the KH performance target under DD1 earthquake ground motion. is implemented. At the moment, I couldn't select advanced performance targets in the performance targets tab in idecad, will this come in updates? Actually, do we have an obligation to burn an advanced performance target? I could not clearly understand this part for such structures. :roll: :roll: . I would be grateful if you share your values.
Re: School project with DTS 1a In buildings with DTS 1a and 2a and at the same time with BYS 2 or 3, you will make two stages of SGTD (Nonlinear calculation) after making DGT, that is, Calculation Based on Strength. You will demonstrate that you meet the Controlled damage (HR) performance target for Tier DD-1. You will demonstrate that you meet the Controlled damage (HR) performance target for Tier DD-3. .tr/egitim-webinarlari/]http://idecad.com.tr/egitim-webinarlari/[/url]
