TUNNEL MOLD
Hello, Since the panels are modeled as shells and considered together with the door/window gaps in the program, you can solve the tunnel formwork systems and get their drawings. However, mesh steel reinforcement type for panels is not included in the program. If you want to use wire mesh, you must do the reinforcement and drawing of the panels yourself. Our users who make applications can add a sample project if they want...
In the tunnel formwork project I made, it gives the error of insufficient reinforcement in the flooring. I couldn't fix this problem, what can I do? I used wicker reinforcement, I connected the curtain ends with tape beams, I also changed the effect distance of the floor calculation axles.
Our technical service cannot give a recommendation without seeing your project, can you send your project?
