tunnel formwork
Hello, Complete the data entry as you did as an example. For the analysis, if you analyze the floor earthquake effects by assuming a semi-rigid diaphragm.
Aren't you going to wire the floors? Select the mesh reinforcement from the flooring settings. If you are not going to make wicker reinforcement, the way the slab calculation axis works is now console. Edit the way it works..
