Transverse reinforcement spacing in beams connected from beam to beam
rcp52
Guys, it does not create a wrapping zone, especially in the protruding outer frame beams. It creates stirrups at 20 cm intervals.
Hello, when defining the confinement zone in beams, it is defined as from the column face. For this reason, a stirrup wrap zone is not created in the beams supported on the beams. Even if you define it manually, you still cannot create it. Maybe manual intervention is allowed.
Simple beams are excluded from this article. Even as a cross-section, you do not have to comply with the beam dimension conditions according to subparagraph (d). ideCAD calculates transverse reinforcement in simple beams and all other beams, also complying with TS 500 conditions.
