Re: transferring your quantity to the idestatics Hello, the work on integration with the progress payment programs has not been cancelled, but the mutual development process is not continuing for now. I suggest you get technical support from Oska. If Oska has changed the file format, there may be a reading problem. You can get this information from oska. Also in the installed folder; In order to share data with Oska, the version of the Oska program that integrates with ideCAD must be installed on your computer. The Oska program is located in the C drive, under the E-oska folder, and in ideCAD it is accepted as this folder by default. If the program is installed in another folder, the oska.ini file located under the ideCAD installation folder must be modified. When you open the Oska.ini file, for example, with the Notepad program, the contents of the file will appear as follows. [OSKA_DB_IMPORT] Value=C:\e-Oska\Oska_IdeCAD\oskaide.osx [OSKA_EXPORT_FOLDER] Value=C:\e-Oska\Oska_IdeCAD\ [OSKA_CONVERTER] Value=OskaCAD.exe "C:\e-Oska" written in the file content " the target directory should be changed to the name of the directory where the Oska program is installed and the file should be saved as changed. check their status.
