Total longitudinal reinforcement area
cagdaserel
Hello Everyone, The longitudinal reinforcement area appears to be different in the Calculation outputs for two of the same type curtains of the same length, for which we calculated the average reinforcement for the urban transformation and entered according to this longitudinal reinforcement area. Is this an error or is it writing another field? Good work, best regards.
It is not an error. Since the design effects of the curtains are different, you see different As values. The As value appearing in the wall reinforced concrete report is not the existing reinforcement area, it is the larger of the reinforcement area found in the design effects in the shear reinforced concrete calculation and the reinforcement area calculated as per the specification. Reinforced concrete dialog and report comparison sample screenshot: Note: The explanation of the term As appearing in the report will be changed in the next version.
