TORSIONARY ERROR IN SHORT CONSOLE BEAMERS
emrebagdu
There is a continuous (Br) error in cantilever beams as short as 45 cm. What should I do to prevent this? (I enlarged the sections, but the problem was not resolved)
If you add your project or contact our technical service, we will have a better chance of examining it.
Mr. Emre, I downloaded your project, but it keeps closing without taking any action. Also, you didn't create the frame. frame columns are connected to each other indirectly....
You have created your system incorrectly. You should make improvements to the system. The K309 beam causes this torsional moment. If you cannot make improvements in the system, you can relase the right end of this beam, that is, you can put a joint. Or you can enter a small value for the torsional moment of inertia of the K324 beam. In the old calculation approaches, we used to place such simple beams to the main beam in such a way that they only give shear force. Now you know that the whole building system is being solved at once.
