Hello, Irregularities of type A1 and b2 are irregularities that affect the reason for choosing the calculation method. When dynamic analysis is performed, these irregularities have no effect according to the method. However, if these irregularity coefficients are to be reduced below the limit value, the carrier in the relevant direction is It is necessary to increase the system rigidity.The regulation also allows the nci value to be between 06-08 in B1 type irregularity. If the nci value is between 0.6-0.8, the R coefficient is multiplied by the 1.25th(min) value as specified in TDy2007 item 2.3.2.3 and the selected R coefficient is Determinations for data entry: *Foundations on the right side of the project are entered in the basement, but the column is not entered. It would be appropriate to enter the columns by giving an elevation in the basement floor. *Foundation piece remained under the S26 column. *Between the ground bearing coefficient and the ground tension. There seems to be an incompatibility... *I think soil group C or D... C and D group soils are based on the Regulation. Me and displacements are requested to be taken into account. For this reason, it is recommended that the foundation system be designed as a beamless raft and analyzed according to the Superstructure interactive solution option. (Stress control on beamed raft foundation in the program is done only according to vertical loads.) Thank you very much, Mr. Levent, I have one more question in my mind, finally, would you recommend me to make a staggered or monolithic plate foundation, because Good work
