to import
kübra
hello, when I import a DWG file, the program gets very slow. I am new to the program. What I want to do is to get objects in architecture. how can I do it?
Before importing, delete the other layouts other than the plan you need, close the layers that are not useful to you in the plan, keep the axis, columns, curtains and walls, run the autocad in purge command and select purge all, import this layout, and when you open the ide, you can measure it. Check the progress, you can enlarge or reduce it with the scale command, save it as a block with the save to file command without entering any objects in the ide, recall the blog and delete the previous layout, now you can use this block layout as a template, you can delete the block after you enter the necessary objects in the ide. good work. G.KÖSE
