To build a pool on the top of the 3-storey building.
adem37oz
Hi guys, I have a job 5 blocks away. Each block is 3 floors. A pool will be placed on the roof in block B. So there will be net 3 floors and a pool on it. How can I design I designed a pool with an area of 60 m2. depth will be 50 cm. I turned around the pool with a 50 cm curtain. How will I bring the sequel? How do I do the flooring part? Also, how do I add a load to the flooring when it falls under the pool? So how do I add the pool load? It's a bit complicated, but if you could help me I would be very grateful.
Hello, my comment without knowing how the project is. Make the structure a semi-rigid diaphragm solution by giving a live load of 1.00*0.5=0.5 t/m2 per m2 to the floors of 60 m2. Also;
"adem37oz":3pvrry7t" said:
I turned the pool perimeter with a 50 cm curtain.
It may be a problem because there are curtains that do not continue from the bottom up. You can add a 50 cm curtain around the pool in the drawing (because the height is low.) Ünver ÖZCAN
Hello, We make comments without seeing your project, but as Ünver said, if you define curtains on the upper floors, the analysis model may be incorrect. The 50cm pool height can be modeled as a low floor. Build the system with beams, sub-beams and slabs and model the required elements by leveling. Check the stage by taking a section.
