Situations determined in terms of data entry in your project; -Your basic data entry is definitely wrong. In the program, the borders of the raft foundations should be created with the slab edge. If it is desired to define a rafter raft foundation, all of the vertical carrier elements should be connected to each other with continuous foundations, and raft slabs should be placed in the cells formed between them. It would be more appropriate to give a single name to P12 and P13 pitches. - Floors D01 and D02 on the ground floor and above are defined as a single console. Single console rib definition is not foreseen in the program. The warning can be seen in the geometry check. -I recommend you to review your project by taking into account the warnings like beam widths in geometry control.
My dear brother. You have some problems with your project. I've written about these before. I see that some of them are still not taken into account. For example, regarding the rafter raft foundation. If you are going to make rafter raft you should pass beams under all columns. You also have to pass beams at the start and end points of all curtains. In addition, I think that some of your beams are horizontal, both in terms of architectural and static design. For example, you have a problem at the points I guess are the elevator shafts. Some of your two-part objects (panel, beam) have two different names. Although your beams are very delicate, I think your curtains and columns are exaggerated. I think this situation is related to design. Maybe when you focus on these issues and reshape them, the problems you mentioned will disappear by themselves. Good luck with.
After the beam passes under each vertical element, the raft does not have any meaning bro. we have to make beams under each vertical carrier element in the raft, in some constructions, beams jump to the sections where the floor safety condition is straight, under the vertical carrier, but they do not throw each vertical carrier element under the continuous beams
It may be done as you mentioned in the application, but when defining a rafter raft as the data entry rule of the program you should define a continuous basis under all vertical carriers.
In the settings of your outermost continuous foundations, enter the lower and upper amplitude options as zero, adjust their thickness and offset so that 60 cm amplitude remains.
If you wish, you can make a raft without beams as in the attached file. Note: Only beamless raft is added to the system. I have not made any corrections to the issues I have written before. They are still valid... Take it easy..
Mine was a suggestion as well as an example in terms of raft drawing without beams. But when the relevant article of the municipal regulation is clear and these conditions are met, I don't know where he gets the right to say "I do not accept" despite the regulation. You should ask this too.
