Time History example with ideCAD
cassabotanic
I prepared a small Time History example. There are curvilinear beams at different levels in the model . Corrected acceleration records of El Centro earthquake were applied to the system in the X direction. The same system was transferred to the sap2000 program and the results were compared. Here I give some values as a summary. Modal analysis Periods ideCAD Sap2000 1st mode 0.14879 0.14879 2nd mode 0.14654 0.14654 3rd mode 0.13285 0.13285 Time History Results K3 beam maximum M33 Moment Left end ideCAD sap2000 10.9854 10.9854 Time History Results K3 beam maximum M33 Moment Right end ideCAD sap2000 12.6842 12. Exactly the same. I include both the ideCAD model and the sap2000 model for you to compare the results yourself.
Mr. Cassabotanic I don't know if it's a good study. So I downloaded your cde file, with version 6.0012, I couldn't open the file, couldn't look at the results. Unfortunately, the screenshots I took do not exist: Can you imagine, you have the latest version of the program and you cannot open the cde file. How difficult it is not to share..
Mr. I am Bolvadin; The project is currently in beta testing and is made with the new version that will be used soon, so you cannot open it. However, if you don't want to wait, the 6.0012 version you have has the same features, you can enter a simple system and try it in the same way.
"Bolvadinim":16hclbbp" said:
Mr. Cassabotanic I don't know if it's a good work. I also downloaded your cde file, I couldn't open the file with version 6.0012, I couldn't look at the results. Unfortunately, there are no screenshots I took: Can you imagine, you have the latest version of the program and cde You can't open the file. How hard it is not to share it..
We are waiting for your comments, Mr. Bolvadin. Being a beta user naturally has some advantages over normal users. They test the program and ensure that it reaches you without errors. A local program name is not required, beta user Mashallah, it releases a new version every day because it can't improve its logic. Download the latest version of ideCAD and enjoy sharing.
Press the right button in the perspective window, choose "3d Frame" from the menu that appears, select the elements from the system, press the right button while the mouse is on any of the selected elements, choose "show graphic functions" from the menu that appears.
