Hello. In the example, even though I give the angle value to the console floor, it still stands flat in the solid model, as the value of the angle I give increases, only the thickness of the floor visible in the solid model increases... Although it has beams on all sides, the D11 floor in the example stays in the air. In addition, when I define cassettes or ribs in Example D1 and D2 tiles in Inclined slab, although the slab is curved, the ribs remain flat under the slab... I would be very happy if you could provide detailed information on this. Because it is needed on reinforced concrete ramps and roofs. Thanks...
                     German
 German  French
 French  Spanish
 Spanish  Portuguese
 Portuguese  Italian
 Italian  Arabic
 Arabic  Russian
 Russian  Japanese
 Japanese  Turkish
 Turkish
